| Version | PLAXIS 2D 2017 PLAXIS 3D 2016 |
| Date created | 23 August 2017 |
| Date modified | 23 August 2017 |
The staged construction settings and values for any Intrinsic properties of all UserFeatures (e.g. a load value for a line load, or a material assignment for a soil) are stored as a listable object per phase.
For instance, if you want to get the material assignment of a Soil_1_1 element in Phase_3, you can get the material object, and show the material name using these Python lines:
material = g_i.Soil_1_1.Material[g_i.Phase_3] print(material.Name.value)
Or, if you want to just show all material assignments for all soil objects:
for phase in g_i.Phases[:]: for soil in g_i.Soils[:]: print("{} in {}: {}".format( soil.Name.value, phase.Name.value, soil.Material[phase].Name.value ) )
You can use the Active property of a soil get to know if it is active or not in a phase:
active_state = g_i.Soil_1_1.Active[g_i.Phase_3] # True of False
To get a complete overview:
phase = g_i.Phase_3 for soil in g_i.Soils[:]: print("{} in {}: {} and Active={}".format( soil.Name.value, phase.Name.value, soil.Material[phase].Name.value, soil.Active[phase] ) )
To set a value for a staged construction setting, we can use this too. To set the vertical component of a point load Fy in Phase_3, you can use this:
g_i.PointLoad_1_1.Fy[g_i.Phase_3] = -10
For most Intrinsic Properties you can just follow the Selection Explorer:
Then you can use this:
g_i.Soil_1_1.Active[g_i.Phase_3] # gives boolean of active state of soil object for Phase_3 g_i.Soil_1_1.Material[g_i.Phase_3] # gives assigned material object for Phase_3 g_i.Soil_1_1.ApplyStrengthReduction[g_i.Phase_3] # gives boolean for Phase_3 g_i.Soil_1_1.WaterConditions # this is a UserFeature of the Soil object for water conditions g_i.Soil_1_1.WaterConditions.Active[g_i.Phase_3] # gives boolean if water is active for Phase_3 g_i.Soil_1_1.WaterConditions.Conditions[g_i.Phase_3] # gives number of water conditions option for Phase_3. E.g. value is 0, means global water level
The above examples are made with PLAXIS 2D 2017.00 and PLAXIS 3D 2016.02 using Python 3.4.x.
