| | Product: | MicroStation | |
| | Version: | V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | Printing | |
| | Subarea: | Driver/PDF | |
Problem Description
Text/Fonts display poorly when printed to PDF format. Some letters look like a different font compared with others in the same word. Other letters appear to have a bold format compared with other letters in the same word/sentence.
Steps to Resolve
The following option can be tried:
- Go to File > Print
- Select the pdf.pltcfg driver (in Print dialog go to File > Select Bentley Driver)
- In Print dialog, go to menu Settings > Print Attributes
- Turn off the Line Weights and click OK
- Choose the desired paper size
- Then Print
When creating a pdf with pdf.pltcfg the fonts in the pdf look pixilated and not rendering correctly when zooming into the pdf.
Other language sources
| | Original Author: | Conor King | |
