| Product(s): | MicroStation | |
| Version(s): | 10.16.00.80 | |
| Environment: | N\A | |
| Area: | Printing | |
| Subarea: | Driver/PDF | |
Print output to design file folder location
How to change the default destination of the plot files from out folder to the same folder as the design file.
- Open the Printer driver configuration “PDF.pltcfg” file
- From Printer dialog, go to "File > Edit Printer Driver Configuration"
- Under "Base Properties > Default Print File Name > File Name", is set to following script
$(MS_PLTFILES)$(basename(_DGNFILE))-$(MS_PLTMODELNAME)-<autoInc?digits=3?base=0
- Change it to
$(_DGNDIR)$(basename(_DGNFILE))-$(MS_PLTMODELNAME)-<autoInc?digits=3?base=0>
- Go to "File > Reload Printer Driver Configuration"
- Now Print
Printer Driver Configurations
Other Language Sources
Deutsch
| Original Author: | Bentley Technical Support Group | |
