Scripting reference and how to use it
ApplicationPLAXIS 2D
PLAXIS 3D
VersionPLAXIS 2D CONNECT Edition V20
PLAXIS 3D CONNECT Edition V20
Date created05 November 2019
Date modified05 November 2019
Since PLAXIS CONNECT Edition V20, extensive documentation is available regarding the Remote Scripting functionality.
This can be found under Help > Scripting reference menu:
scripting_reference_1
The documentation is based on
Jupyter notebooks and requires the activation of the Remote scripting server. More information on the scripting server can be found in the article Using PLAXIS Remote scripting with the Python wrapper.
The documentation is launched on a browser window and includes information and full examples of all available commands in PLAXIS Input & Output programs.
Workflow explained
In order to use the Scripting reference, you can follow the workflow below:
  1. Identify command to run with Python scripting
     - use Graphic User Interface (GUI) or check the command line session
     - use Help > Command reference
  2. Go to PLAXIS Input program (also for Output commands)
  3. Open menu Help > Scripting reference
  4. Set up the Configure remote scripting server window
  5. Find the command for Input or Output in alphabetical order
  6. Click on the command name (the example will open in new tab)
  7. ►| Run (cell by cell)
    or
    select: Cell > Run All
  8. Jupyter notebook runs the example and provides the response(s) from Plaxis
  9. Check PLAXIS Input/Output to see the example
scripting_reference_2
Figure 1. Scripting reference Jupyter notebook
scripting_reference_3
Figure 2. Python example for command calculate
For more information on Python Jupyter Notebooks, follow the link to:
https://jupyter-notebook.readthedocs.io/en/stable/
See also
