| Version(s): | 08.11.09.459 | ||
| Area: | Printing | ||
| Subarea: | Driver/PDF | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
How to suppress the pdf driver's "Save As" dialog and save pdfs to a specific local directory
Choose File>Select Bentley Driver; choose "pdf.pltcfg"
Choose File>Edit Printer Driver Configuration
On the "Base Properties" tab, select "Default Print File Name"
In the "File Name" field, type in: c:\pdfs_only\$(basename(_DGNFILE))
Set "Auto Overwrite File" to "True"
Save and Exit menu
Choose File>Reload Printer Driver Configuration
Note: Local directory in step 5 should be created prior to creating pdfs
