| Version: | v8i, CONNECT | ||
| Area: | DWG | ||
| Subarea: | Save |
How to convert a DGN to DWG. Issues when converting a DGN (MicroStation) file to a DWG (AutoCAD) file.
In order to convert a DGN file to DWG format.
Steps:
1) Open the DGN file in MicroStation using File > Open
2) From Menu bar, Choose File > Save As.
3) Use [Save as type:] drop down and change to: Autodesk DWG Files (*.DWG)
4) Click [Options] and change desired settings.
Some common settings to toggle ON would be the "Drop Unsupported LineStyles" and "Drop Unsupported Dimensions" options contained in General tab>Advanced Section.
5) Once desired settings are set, click OK and then Save. Press OK again if prompted.
