| Version: | All Versions | ||
| Area: | Levels | ||
| Subarea: | Level Manager |
What does ByLevel Attributes mean?
ByLevel Attributes are element properties (Color, Line Style, Line Weight) which are controlled from a level's properties.
ByLevel attributes can be modified or changed for the entire level using the Level Manager. They are very useful as they can allow property changes to many elements at once.
Determining Attribute ByLevel Status
| Original Author: | Bentley Technical Support |
