API / Python scripting - PLAXIS LE
This section contains examples and demonstrations on using the PLAXIS LE API and the Python module.
Introducing the PLAXIS LE Slope Stability Solver API
We introduce creating your Limit Equilibrium models using PLAXIS LE's API in PLAXIS 2D/3D LE V21.01: it is available as a Tech Preview Python module.
