| Version | PLAXIS 2D CONNECT Edition V20 and later PLAXIS 3D CONNECT Edition V20 and later |
| Date created | 29 April 2015 |
| Date modified | 24 July 2022 |
The PLAXIS software provides an HTTP-based API (REST HTTP API), for which a special Python wrapper was developed for an easy-to-use scripting API. Both PLAXIS Input and PLAXIS Output support this usage of a Remote Scripting server.
The information in this article applies to both 2D and 3D 2017 versions and later, as well as to 3D 2016 version. For older versions, please see the attachment at the end of this article.
In order to use this:
In order to start using this Remote Scripting/REST HTTP API, the remote scripting server inside PLAXIS needs to be activated.
This can be done by opening the menu item Expert > Configure remote scripting server.
The corresponding window will pop up, see Figure 1 for PLAXIS 2D and PLAXIS 3D:
Figure 1. Configure remote scripting server window in PLAXIS 2D and PLAXIS 3D
For the Remote Scripting server to run, you would need:
Figure 2. Run the remote scripting server requirements:
1) a valid license, 2) a password and 3) a local connection port
In order to start your first Python script, you can start SciTE from PLAXIS. First, we must import the PLAXIS scripting library. Then, you must make sure that your Python script can communicate with the PLAXIS application (assuming the scripting server port was set to 10000, see above):
from plxscripting.easy import * s_i, g_i = new_server('localhost', 10000, password='yourpassword')
In this, we need to set the correct localhost port using the same number as set in the Configure remote scripting server window as well as the password field required.
Now we have two new variables:
For PLAXIS Output, the recommended variable names are:
Note, if you want to use both PLAXIS Input and PLAXIS Output in your Python script, you will need to set up the connection with Input and Output separately by binding the server and the global object for Input and Output separately using each their own port number:
# PLAXIS 2D and PLAXIS 3D # [...] localhostport_input = 10000 localhostport_output = 10001 from plxscripting.easy import * s_i, g_i = new_server('localhost', localhostport_input, password='yourpassword') s_o, g_o = new_server('localhost', localhostport_output, password='yourpassword')
If your script gives an error, please check the following:
For more details on this Python wrapper and some code examples, please see the appendix on the Python HTTP REST API wrapper in the PLAXIS Reference manual and the related links.
Starting January 1st, 2022, the PLAXIS HWL versions and the VIP subscription have been discontinued. This includes access to the PLAXIS Remote Scripting services for these versions. To allow time for transition to the PLAXIS CONNECT Edition version, the Remote Scripting Server services for PLAXIS HWL versions will continue to function until December 31, 2022. After this date, the Remote Scripting Server services will be discontinued.
