| Version: | CONNECT | ||
| Area: | View | ||
| Subarea: | General |
I am trying to set a display depth using DP=15,100 so that I only see elements above elevation 15 but the displayed elements are not changing
For the display depth to be taken into account, the selected view must have its Clip Back and Clip Front view attributes enabled.
| Original Author: | Judy Wong |
