| Area: | View | ||
| Subarea: | General |
How to toggle a Views background color via keyin
The User Preference View Options > Black Background -> White can be set with a key-in.
Open the Key-in dialog from the ribbon, if not already open (Drawing > Home > Primary > Key-in).
Enter the following key-in to toggle the background color to white or black.
calculator userPrefsP->flags.invertBackground=!userPrefsP->flags.invertBackground;update view all
How to set the View background color from white to black in Connect Edition
| Original Author: | Carl Myhill |
