| Version(s): | 10.15.02.11 | ||
| Area: | Other | ||
| Subarea: | N\A |
SQLite error when starting MicroStation
User gets the following error when starting MicroStation. From the error description, it looks like a privilege issue.
Starting MicroStation as Administrator fixed the issue.
Right click MicroStation shortcut and Run as Administrator.
Alternatively do check if logged in User has Read/Write access to folder %localappdata%
Open File Explorer and type %localappdata% which expands to following folder
C:\Users\{UserName}\AppData\Local\Bentley\
