| Version(s): | V8i and CONNECT | ||
| Area: | Coordinate Systems | ||
| Subarea: | Geographic |
How can the attached geographic coordinate system be deleted?
The Geographic Coordinate System attached to a model can be deleted by clicking on the "Delete Geographic Coordinate System" tool (the rightmost icon) in the Geographic Coordinate System dialog. MicroStation asks you to confirm this operation:
Remove the GCS through key-in command "GEOCOORDINATE DELETE"
Assigning A Geographic Coordinate System
Reprojecting to a new Geographic Coordinate System
