New in PLAXIS LE 2D/3D CONNECT Edition V21 - Update 2
Release: June 2021
PLAXIS 2D/3D LE CONNECT Edition V21 Update 2 (21.02.00.170) contains the following improvements and updates compared to PLAXIS LE CONNECT Edition V21 Update 1:
New features
Input and Visualization Improvements
A collection of improvements across the Input & Output modules to further reduce model setup time and to view more when performing model design reviews.
Slope Stability Blast Disturbance Zone [Technology Preview]
For mining applications, specify spatially a blast zone and corresponding material strength reduction curve without adding complexity to your 2D or 3D model geometry definition.
Slope Stability Python API [Technology Preview]More features exposed through the Python package, offering direct access to the LEM Slope Stability Solver to further automate modeling scenarios.
API / Python scripting - PLAXIS LE Resources.
User requests
The following user requests have been incorporated in this release:
- [615378] PLAXIS Designer: Importing a Block model dataset prompts to copy to project folder to preserve link to data file
- [328263] PLAXIS LE - Slope Stability: Added arbitrary orientation custom slice views in 3D models in addition to views parallel to axes
- [481401] PLAXIS LE - Slope Stability: Added display of water iso-surfaces input from a Groundwater analysis
- [336127] PLAXIS LE - Slope Stability: Improved display of contouring of discrete points input of pore-water pressure to exclude data outside the model geometry
- [614150] PLAXIS LE - Slope Stability: Corrected the graph of Shear Stress vs Normal Stress when entered in terms of a Cohesion-Friction Angle for the Anisotropic Linear Material (ALM2) shear strength type input
- [573262] PLAXIS LE - Slope Stability: Corrected display control hierarchy for Visibility/Fill/Opacity for Material Volumes Meshes (MVMs) and Bedding Guides
- [573211] PLAXIS LE - Slope Stability: Added more advanced Kriging options for pore-water pressure discrete points input
- [608530] PLAXIS LE - Slope Stability: Improved display of sliding masses in custom slice views offset from the sliding direction
- [529857] PLAXIS LE - Slope Stability: Improved 3D slicing algorithm to address special cases reported when using Material Volume Meshes (MVMs) when executing 2D MPA analyses
- [573210] PLAXIS LE - Slope Stability: Warning now provided when using spline interpolation on very large discrete points pore-water pressure input data sets, where system resources may be exceeded
- [616350] PLAXIS LE - Slope Stability: Improved Unsaturated User Defined material type to allow entry of Shear Stress vs Suction data corresponding to a Normal Stress state other than zero
- [556725] PLAXIS LE - Slope Stability: Added ability to change display format of labels for Loads
- [604141] PLAXIS LE - Groundwater: Added display of Piezometers in 3D sliced views and added projection distance from slice tolerance control for CPTu and Piezometer display
- [580138] PLAXIS LE - Groundwater: Added option to extend solver time discretization following precipitation events
- [579154] PLAXIS LE - Groundwater: Changed new climate boundary conditions to apply Runoff by default
- [553680] PLAXIS LE - Groundwater: Added model Water Balance Cumulative and Water Balance Rate output graphs
- [615186] PLAXIS LE - Groundwater: Fixed case where 3D water table display color changed after toggling on/off
- [556724] Added support for vertical axis labels and titles in graphs
- [572734] Added a date format option to graph labels
- [617110] Made actions more visible when creating a new Project through the PLAXIS LE Manager
- [573264] Multiple artwork fixes and improvements, including context menu additions and more 3D selection control
- [589427] Various improvement to 3D slice view display and performance
- [607955] Improved registry setting options for system administrators wanting to configure environments for use with PLAXIS LE
- [594937] Users can disable MS Access 2016 database component during installation to prevent conflicts with Microsoft Office installations on some computers
Fixed issues
A large number of issues have been addressed, including:
- [581079] PLAXIS LE - Slope Stability: Fixed a case where slicing was off when slip surface optimization was used with the Sarma Non-Vertical Slices calculation method
- [526089] PLAXIS LE - Slope Stability: Improved selection of distributed loads in 3D view
- [615208] PLAXIS LE - Slope Stability: Fixed an issue with saving of a Line Load acting point
- [609065] PLAXIS LE - Slope Stability: Fixed a null reference exception when using the Grouted Tieback with Friction support type
- [606227] PLAXIS LE - Slope Stability: fine-tuned the 2D slicing algorithm to handle some special cases, such as a horizontal ground surface
- [601405] PLAXIS LE - Slope Stability: Fixed an issue with optimization of a fully-specified slip surface if the end points were defined outside of the slope boundary
- [588216] PLAXIS LE - Slope Stability: Fixed the display of the slip surface outline when a 3D cuckoo search was used specifically with Gao's method for determining the sliding direction orientation
- [595005] PLAXIS LE - Slope Stability: Updated 3D FOS custom color map
- [573066] PLAXIS LE - Slope Stability: Probability of failure now shown in output legend and in critical mass label
- [580004] PLAXIS LE - Slope Stability: Fixed problem of keeping surface name edits for a Surface update from PLAXIS Designer
- [595008] PLAXIS LE - Slope Stability: Fixed rounding issue for 2D optimization in a model with extremely dense region points
- [615301] PLAXIS LE - Slope Stability: Tab to allow entry of cohesion and friction angle was not displaying for the Unsaturated User Defined material type
- [618633] PLAXIS LE - Slope Stability: Model offset option now supports discrete points
- [602282] PLAXIS LE - Groundwater: Corrected conversion of directional parameters when importing a material with hydraulic conductivity anisotropy between 2D and 3D models
- [601505] PLAXIS LE - Groundwater: Boundary condition objects were not being accounted for in some cases when slicing a 3D model to create a 2D model
- [598898] PLAXIS LE - Consolidation: Models were not listed in the PLAXIS LE Manager if they were saved while in certain view modes
- [607024] Fix for the PLAXIS 2D-PLAXIS LE Importer to support non-English Regional Language settings
- [612948] Corrected display of some output objects when exporting to PDF
- [576819] New distribution example models now scanned and listed in the PLAXIS LE Manager when upgrading from V10.x to V21.01
- [589574] Boundary Conditions and Blast Disturbance Zones now offset properly when using the Model Offset feature
Download links
