PLAXIS product licencesImproved product licensing options under the PLAXIS brand: PLAXIS 2D LE, PLAXIS 3D LE and PLAXIS Designer. See
here for more details.
For V21 and onward, SVSLOPE, SVFLUX, SVSOLID, and SVSOILS products will be now availabe under PLAXIS LE products, see
here for the changes.
Defining different shear strength above the water table
The option to define an alternate material shear strength in the unsaturated zone above the water table, without having to adjust your complex model geometry, offers you a significant reduction in model setup time with this release of PLAXIS LE - Slope Stability Analysis. The Above Water Table Use Strength gives the option to define a material to reference an alternate material definition above the watertable and remove the need to define extra model geometry!
Export to PLAXIS 2D [Technology Preview]
PLAXIS LE Slope Stability LEM material parameters added to the existing Geometry Export allowing quicker model setup for performing FEM safety analysis or sharing model geometry for other FEM analysis types.
Take sections directly from PLAXIS Designer 3D conceptual designs to PLAXIS 2D analysis.
PLAXIS LE Manager Upgrade
Re-design of the SOILVISION Manager adds more flexibility of project and model organization and material definitions can be shared and linked from other model files or the SoilVision Soils database.
Many issues have been fixed for this release.
