| Version(s): | 10.00.00.25 | ||
| Area: | Configuration | ||
| Subarea: | User Preferences |
How to enable multiple Application Windows in MicroStation CONNECT Edition?
Previous version of MicroStation allowed either a single application window or two windows. This release up to four application windows can be opened for multiple display monitors.
Here on the left hand side you will see a menu with a number of options, Select the Settings option from the menu.
Under the User Settings area you will find the Preferences area.
The Preferences dialog will open where you should go to the Operation option. Here you will find the section entitled "Open Multiple Application Windows". Once this has been selected the pulldown box to the right can be selected and between 2 - 4 application windows can be selected to open with your session of MicroStation. To disable this option just untick it.
How to move Views to Application Window 3 and 4
Español Deutsch , Français Italiano
| Original Author: | Andrew Bell |
