| Version: | 08.05.02.27 | ||
| Area: | Configuration | ||
| Subarea: | General |
Setting MS_DESIGNSEED but it is still defaulting to the last known seed file.
Lock the MS_DESIGNSEED using the following syntax
%lock MS_DESIGNSEED
