Tensile behaviour in the Hoek-Brown model
ApplicationPLAXIS 2D
PLAXIS 3D
VersionPLAXIS 2D CONNECT Edition V22.02
PLAXIS 3D CONNECT Edition V22.02
Date createdOctober 2022
Date modifiedOctober 2022
Original authorMicha van der Sloot - Bentley User Success Group
The Hoek-Brown model is a well-known elastoplastic constitutive rock model that can simulate the behaviour of homogeneous and isotropic rock ranging from intact to heavily jointed rock mass. The Hoek-Brown criterion provides a non-linear approximation of the rock strength using a continuous formulation of the shear strength and the tensile strength.
The tensile limit of the Hoek-Brown criterion σt for the rock mass is defined as:
Hoek Brown equaiton
Hoek-Brown failure criterion in σ'<sub>1</sub>- σ'<sub>3</sub> plane with indication of σ<sub>t</sub>
Figure 1. Hoek-Brown failure criterion in σ'1- σ'3 plane with indication of σt
Tension limitation
There could be situations in which you would like to limit the tensile capacity of the rock mass, for instance when a rock cut is created by blasting, and one cannot, or should not, rely on the tensile capacity due to generated (micro)fractures.
This can directly be controlled in PLAXIS by activating the tension cut-off option and defining an upper limit for the tensile stresses: the tensile strength. In the case of not allowing any tension in the rock mass for this material, the tensile strength can be set to a value of 0 kN/m2.
Hoek-Brown material definition (left) and failure criterion in in σ'<sub>1</sub>- σ'<sub>3</sub> plane (right)
Figure 2. Hoek-Brown material definition (left) and failure criterion in σ'1- σ'3 plane (right)
Note: this tension cut-off option is introduced in PLAXIS Version 22.02
Tensile behaviour in Safety analysis
In a Safety analysis, the PLAXIS calculation process will reduce the shear strength with increasing ΣMsf. For the Hoek-Brown model, it means that the "slope" of the Hoek-Brown criterion in p'-q plane will be reduced with a fixed apex point [Benz, et al. (2007)]. This implies that during this strength reduction method, the tensile limit remains at σt if no additional limitation for the tensile strength is specified.
Strength reduction in the Hoek-Brown model: original definition (left) and reduced strength line (right)
Figure 3. Strength reduction in the Hoek-Brown model: original definition (left) and reduced strength line (right)
With the introduction of the tension cut-off option in PLAXIS V22.02, it is now also possible to reduce the tensile strength during a Safety analysis. Users can specify a value for the tensile strength equal to σt or any other user-defined value by explicitly activating the tension cut-off option. During the Safety analysis, the current tensile strength is then also updated as a function of the strength reduction factor as:
current tensile strength = user-defined tensile strength / ΣMsf
Hoek-Brown model with tensile strength defined (left) and ΣM<sub>sf</sub>-factorized values during a Safety analysis (right)
Figure 4. Hoek-Brown model with tensile strength defined (left) and ΣMsf-factorized values during a Safety analysis (right)
Example strength reduction
A simplified case is demonstrated here: a stressless block with a Hoek-Brown material, see geometry in Figure 5 and Hoek-Brown material properties in Table 1, is loaded in extension.
Hoek-Brown unit cell loaded in extension
Figure 5. Hoek-Brown unit cell loaded in extension
ParameterSymbolValueUnit
ModelHoek-Brown
Weightγunsat=γsat0kN/m3
StiffnessErm2.4 x 106kN/m2
Poisson's ratioν0.2
Uni-axial compressive strength intact rock|σci|3380kN/m2
Intact rock parametermi7
Geological Strength IndexGSI650
DisturbanceD0
Rock mass: strength in compressionσc-479.9kN/m2
Rock mass: strength in tensionσt34.50kN/m2
Table 1. Hoek-Brown parameters for unit cell extension test
The calculation procedure for this plane strain model is as follows:
Without the tension cut-off value, the calculation process is not able to reduce the tensile strength, and the ΣMsf value increases to large values without leading to an upper limit. When activating the tensile strength equal to σt, the strength reduction factor ΣMsf should reach:
tensile strength / active load = 34.5 kN/m2 / 30 kN/m2 = 1.15
This is also the value we see in the calculation results when activating the tensile strength, see Figure 6 below.
Evolution of ΣM<sub>sf</sub> vs. displacements without tension cut-off (blue) and with tension cut-off (red)
Figure 6. Evolution of ΣMsf vs. displacements without tension cut-off (blue) and with tension cut-off (red)
Conclusion
PLAXIS allows more control of the tensile behaviour with the activation of the tension cut-off option in the Hoek-Brown model. Also, when reducing the shear strength in a PLAXIS Safety analysis, we can now also reduce this tensile strength with the same factor, providing more realistic safety factors when developing failure mechanisms are related to these Hoek-Brown materials.
Note: The tensile behaviour in the Hoek-Brown with Softening model (UDSM) is defined in a different manner. Please see the documentation for more details.
Reference
Benz, T., Schwab, R., Vermeer, P.A., Kauther, R.A. (2007). A Hoek-Brown criterion with intrinsic material strength factorization. Int.J. of Rock Mechanics and Mining Sci., 45(2), 210–222.
doi: https://doi.org/10.1016/j.ijrmms.2007.05.003
Downloads
See also
Hoek-Brown failure criterion    [Publication]
