| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 22 August 2018 |
| Date modified | 21 September 2020 |
The Creep-SCLAY1S model is capable of simulating the anisotropic and rate-dependent behaviour of soft soils. The mathematical formulation also includes the possibility to model bonding and destructuration. Many constitutive models have been proposed in literature to describe the behaviour of structured natural clays. Most of the rate-dependent models were developed based on the Perzyna's (Perzyna (1963) and Perzyna (1966)) overstress theory (e.g. Hinchberger & Rowe (2005) and Zhou, Yin, Zhu & Cheng (2005)), with the disadvantage of a difficult parameter calibration process (Karstunen & Yin (2010)). Another approach consists in using empirical formulations, as for example the Soft Soil Creep model available in the PLAXIS standard library. The Creep-SCLAY1S can be considered a special kind of extended overstress model derived from an empirical equation (Sivasithamparam, Karstunen & Bonnier (2015))
With the release of PLAXIS 2D/3D CONNECT Edition V20 Update 1 (January 2020), the PLAXIS User Defined Soil models are delivered with the PLAXIS installation. When enabling the Geotechnical SELECT Entitlement [GSE] when starting the PLAXIS application, this model becomes available in the Parameters tab when selecting "User-defined" for the Material model.
