| Version(s): | 10.00.00.25 | ||
| Area: | Properties | ||
| Subarea: | Item Types |
How can we upgrade TagSet from previous version's to ItemType in MicroStation Connect Edition.
The following video will introduce you to “Upgrade TagSet to ItemType” in MicroStation Connect Edition and covers the following features:
• Locate the Item Type dialog and execute the Upgrade Tag Set tool.
• Update Item values through the Properties dialog.
• Place Item as Field with Relative Association option ON.
• Apply Text Styles to Items.
| Original Author: | Leonard Jones |
