Videos - GeoStudio
More videos can be found on the GeoStudio YouTube channel. There you can also find release videos, introductory tutorial videos for each product, and video series on specific topics.
Defining Anisotropic Surfaces in 2D Stability Analyses
This video reviews how to add anisotropic surfaces to a 2D stability analysis in GeoStudio. Anisotropic surfaces are used to generate directionally dependent shear strength. They represent discontinuities with significantly different strength properties from the surrounding material.
Defining Anisotropic Surfaces in 3D Stability Analyses
This video reviews how to add anisotropic surfaces to a 3D stability analysis in GeoStudio. Anisotropic surfaces are used to generate directionally dependent shear strength. They represent discontinuities with significantly different strength properties from the surrounding material.
Defining Body Arrays in 3D Stability Analyses
This video reviews the functionality for creating a set of lines or points using the 3D Body Array tool.
Defining Reinforcements in 3D Stability Analyses
This tutorial reviews the process for applying reinforcement properties to line arrays in 3D limit equilibrium stability analyses in GeoStudio.
Defining Weak Surfaces in 2D Stability Analysis
This video reviews how to add weak surfaces to 2D stability analyses in GeoStudio. Weak surfaces have a unique material associated with them and influence the sliding mass shape by truncating any slip surfaces intersecting the weak surface.
Defining Weak Surfaces in 3D Stability Analysis
This video reviews how to add weak surfaces to 3D stability analyses in GeoStudio. Weak surfaces have a unique material associated with them and influence the sliding mass shape by truncating any slip surfaces intersecting the weak surface.
GeoStudio Viewer for SES Licenses
This video demonstrates how to use GeoStudio Viewer for reviewing project files, while on the Bentley SES licensing system.
Hoek-Brown Material Model
This tutorial introduces the fundamentals of the Hoek0–Brown constitutive model and demonstrate how to use it in GeoStudio for limit equilibrium and stress-strain analysis.
Importing 2D sections from Central into GeoStudio
This video covers importing 2D sections created in Leapfrog into GeoStudio from Central.
Importing 3D Models from Central
This video covers importing 3D models into GeoStudio directly from Seequent Central.
Importing DXF Files with Closed and Open Polylines into GeoStudio
This video shows how to import DXF files into GeoStudio that contain closed and open polylines with AutoCAD and MapTek Vulcan as examples.
Importing OBJ Files into GeoStudio
This video demonstrates the workflow for importing OBJ files to set up the geometry for 3D Limit Equilibrium analysis in GeoStudio.
Locating Critical Slip Surfaces with Automatic Search Algorithms in GeoStudio 2D
This video reviews the automatic search algorithms available in GeoStudio 2D, including a review of how the algorithms work and how to define the associated parameters in GeoStudio.
Reducing Resolution of 2D Sections Imported from Central
This tutorial video reviews how to reduce the number of points on cross-sections that are imported via Central from Leapfrog projects.
Using GeoCmd to Solve Models in GeoStudio
This video shows you how to use GeoCmd to solve one file as well as multiple files for all GeoStudio analysis types and geometries.
See also
GeoStudio Geotechnical Analysis    [YouTube Videos]
Online Learning - GeoStudio    [Videos]
Examples - SLOPE/W - Overview    [Examples]
Examples - SEEP/W - Overview    [Examples]
Examples - SIGMA/W - Overview    [Examples]
