| Applies To | MicroStation Print dialog | ||
| Version(s): | 08.11.09.292 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | Printing | ||
| Subarea: | |||
| Original Author: | Dawn Clark, Bentley Technical Support Group | ||
Print Organizer dialog will not display in MicroStation on a specific computer. No error is given.
The ‘PrintOrganizerSettings.xml’ has become corrupt.
Copy ‘PrintOrganizerSettings.xml’ from a functional workstation and replace on the
offending workstation.
C:\Users\cmeszler\AppData\Local\Bentley\MicroStation\8.11\o_Dof88niaENmS1PChQ4Mg\PrintOrganizerSettings.xml
