| Version | PLAXIS 2D CONNECT Edition PLAXIS 3D CONNECT Edition |
| Date created | 11 April 2014 |
| Date modified | 01 November 2022 |
The echo command can be used to display the details of the PLAXIS project:
0004> echo Project named "Project" Title: "Excavation in Sand" Company: "Seequent - The Bentley Subsurface Company" UnitForce: kN (1) UnitLength: m (2) UnitTime: day (3) WaterWeight: 10 Gravity: 9.81 ReferenceTemperature: 293.15 LiquidSpecificHeatCapacity: 4181.3 LiquidThermalConductivity: 0.0006 LiquidLatentHeat: 334000 LiquidThermalExpansion: 0.00021 LiquidTemperature: 293.15 IceSpecificHeatCapacity: 2108 IceThermalConductivity: 0.0022200000000000003 IceThermalExpansion: 5E-5 VapourSpecificHeatCapacity: 1930 VapourThermalConductivity: 2.5E-5 VapourSpecificGasConstant: 461.5 UseTemperatureDepWaterPropsTable: False TemperatureDepWaterPropsTable: 36 rows, 5 columns: Temperature, Density, ThermalConductivity, SpecificHeatCapacity, DynamicViscosity Logo: Mode: Soil (0) GravityDirection: 3
Or the information for an object like a point in PLAXIS 2D:
0007> echo Point_1 Point named "Point_1" x: 1 y: 2
And in PLAXIS 3D:
0007> echo Point_1 Point named "Point_1" x: 1 y: 2 z: 0
This echo command can also be used to retrieve more detailed information than is available via the standard User Interface options: in the PLAXIS user interface, numbers are shown by default with 4 significant figures (adjust under the Options menu). When coordinates are defined in more significant figures, you can still see the exact value of such a parameter by using the echo command.
0009> echo Polygon_1 Polygon named "Polygon_1" x: 2.5 y: 30 Points: PlxHelperPointList named "Polygon_1.Points" Count: 4 0/-4. HelperPoint named "Polygon_1.Points[0]" 1/-3. HelperPoint named "Polygon_1.Points[1]" 2/-2. HelperPoint named "Polygon_1.Points[2]" 3/-1. HelperPoint named "Polygon_1.Points[3]" Features: 1 Soil named "Soil_2" on Polygon_1 Material: SoilMat named "Core" ApplyStrengthReduction: True Features: 3 WaterConditions named "WaterConditions_2" on Soil_2 Conditions: Global level (0) VolumeStrain named "VolumeStrain_2" on Soil_2 ThermalConditions named "ThermalConditions_2" on Soil_2 TemperatureConditions: None (0) EnergyConditions: None (0) Points: 0: (2.5; 30) 1: (10; 0) 2: (-10; 0) 3: (-2.5; 30)
0231> echo Polygon_1 Polygon named "Polygon_1" x: 34 y: 19 z: 0 AxisFunction: Automatic (0) Points: 0: (34; 19; 0) 1: (41; 19; 0) 2: (41; 12; 0) 3: (34; 12; 0)
0120> echo FullReservoir_Steady UserWaterLevel named "FullReservoir_Steady" WaterSegments: WaterSegments named "WaterSegments_1" Count: 3 0/-3. WaterSegment named "WaterSegment_1" 1/-2. WaterSegment named "WaterSegment_2" 2/-1. WaterSegment named "WaterSegment_3" Points: 0: (-132; 25) 1: (-10; 25) 2: (93; -10) 3: (132; -10)
0303> echo High_Reservoir UserWaterLevel named "High_Reservoir" Points: 0: (-130; 0; 25) 1: (-10; 0; 25) 2: (93; 0; -10) 3: (130; 0; -10) 4: (130; 50; -10) 5: (93; 50; -10) 6: (-10; 50; 25) 7: (-130; 50; 25)
The echo command will show all properties for an object, see e.g. the echo Point_1 command above. Also, this echo command can be used to retrieve the correct name for any property/parameter and its correct upper/lower casing for the Python wrapper for Remote Scripting.
Below is an example to show all parameters and their values for a soil material and a phase.
0038> echo Sand SoilMat named "Sand" General: MaterialSet: Identification: "Sand" SoilModel: Mohr-Coulomb (2) DrainageType: Drained (0) Colour: 15262369 Comments: "" UnitWeights: gammaUnsat: 17 kN/m³ gammaSat: 20 kN/m³ VoidRatio: eInit: 0.5 nInit: 0.33333333333333331 RayleighDamping: RayleighDampingInputMethod: SDOF equivalent (1) RayleighAlpha: 0 RayleighBeta: 0 TargetDamping1: 0 % TargetDamping2: 0 % TargetFrequency1: 0.1 Hz TargetFrequency2: 1 Hz Mechanical: Stiffness: ERef: 13000 kN/m² nu: 0.3 Alternatives: GRef: 5000 kN/m² EOed: 17500 kN/m² StiffnessDepthDependency: EInc: 0 kN/m²/m verticalRef: 0 m WaveVelocities: Vs: 53.714933841968557 m/s Vp: 100.49143949493762 m/s Strength: Shear: cRef: 1 kN/m² phi: 30 ° psi: 0 ° ShearStrengthDepthDependency: cInc: 0 kN/m²/m verticalRef: 0 m Tension: TensionCutOff: True TensileStrength: 0 kN/m² ExcessPorePressureCalculation: ExcessPorePressureDetermination: nu-undrained definition (0) UndrainedNuDefinitionMethod: Direct (0) nuUEquivalent: 0.495 SkemptonB: 0.97826086956521715 Kwn: 487499.99999999968 kN/m² Groundwater: Model: GroundwaterClassificationType: Standard (0) GroundwaterSoilClassStandard: Coarse (0) Soil: ClayFraction: 10 % SiltFraction: 13 % SandFraction: 77 % FlowParameters: Permeabilities: GwUseDefaults: False PermHorizontalPrimary: 0 m/day PermVertical: 0 m/day VoidRatioDependency: False cK: 1000000000000000 Porosity: nInit: 0.33333333333333331 UnsaturatedZone: GwPsiUnsat: 10000 m Thermal: ThermalDiffusion: ThCs: 0 kJ/t/K ThLambdaS: 0 kW/m/K rhoS: 2.6 t/m³ ThermalStrain: ThermalExpansionType: Isotropic (1) ThAlphaSV: 0 1/K FreezingThawing: PhaseChange: False VapourDiffusion: Dv: 0 m²/day fTv: 0 Interfaces: InterfacesStiffness: InterfaceStiffnessDetermination: Derived (0) InterfacesStrength: InterfaceStrengthDetermination: Rigid (0) Rinter: 1 GapClosure: True InterfacesGroundwater: CrossPermeability: Impermeable (0) DrainageConductivity: 0 m³/day/m InterfacesThermal: Rthermal: 0 m²·K/kW InitialProperties: K0Settings: K0Determination: Automatic (0) K0Primary: 0.5 K0Secondary: 0.5
In the example above, we assumed we have a material with the name Sand.
0039> echo Phase_1 Phase named "Phase_1" Number: 1 Identification: "Indentation" PreviousPhase: InitialPhase named "InitialPhase" DeformCalcType: Plastic (4) PorePresCalcType: Phreatic (0) MaxCores: 256 LogInfo: "OK" MaxStepsStored: 1 TimeInterval: 0 ShouldCalculate: False CalculationResult: OK (1) FirstStep: 1 LastStep: 185 DesignApproach: SpecialOption: 0 UseCompressionForResultFiles: False Features: 3 Deform named "Deform_1" on Phase_1 UseDefaultIterationParams: True MaxSteps: 1000 ToleratedError: 0.01 OverRelaxation: 1.2 LoadingType: Staged construction (1) UseUpdatedMesh: False UseUpdatedWaterPressures: False IgnoreSuction: True UseCavitationCutOff: False CavitationStress: 100 ArcLengthControl: On (1) MaxUnloadingSteps: 5 MaxLoadFractionPerStep: 0.5 UseSubspaceAccelerator: False SubspaceSize: 3 UseLineSearch: False UseGradualError: False IgnoreUndrainedBehaviour: False ResetDisplacementsToZero: True ResetStateVariables: False ResetSmallStrain: True ResetTime: False MaxIterations: 60 DesiredMinIterations: 6 DesiredMaxIterations: 15 SumMweight: 1 Features: 1 Loading named "Loading_1" on Deform_1 SumMstage: 1 Reached named "Reached_1" on Phase_1 Time: 0 RelativeStiffness: 0.019014589100625117 Pmax: 0 SumMstage: 1 SumMweight: 1 SumMsf: 1 AngularForceX: 0 AngularForceY: -93.56190075864457 Flow named "Flow_1" on Phase_1 ThermalCalcType: Ignore temperature (0)
The echo command can also be used to get information for a specific object property. Examples:
Note, to change such a property, the set command or the setproperties command can be used:
For more details on the echo command or any other command, please refer to the Plaxis Command Reference, available via the Help menu.
