| Version | PLAXIS 2D CONNECT Edition PLAXIS 3D CONNECT Edition |
| Date created | 17 November 2022 |
| Date modified | 17 November 2022 |
| Original author | Stefanos Papavasileiou - Bentley Technical Support Group |
When working with any PLAXIS application, you may encounter an error and the following pop-up window might appear, as shown in Figure 1.
In this article, you will understand the options available and the recommended action once this occurs.
Figure 1. Pop-up window appearing when an error is encountered
The moment this window appears it means that PLAXIS has encountered an issue and therefore it was not possible to fully perform the task requested.
This pop-up window gives the options:
and the follow-up actions when it comes to the application running at that moment:
The main window will remain open, regardless of which option you may select, until a follow-up action is selected.
This option will gather any necessary files to report the encountered issue in a temporary folder and launch your internet browser to submit a Service Request.
This includes:
You can attach these files as attachments when you submit a Service Request for further assistance.
This option will open a window in which you can select where to save the bug report file generated - bugreport.txt. This is a text file that contains essential information about the code considered in this issue.
You can provide this file as an attachment when you submit a Service Request for further assistance.
This option opens a window in which all the details of the bug report are presented.
This is mostly used for debugging purposes by the PLAXIS team.
In the case that an issue is encountered, and the bug report information appears, the PLAXIS application requires a follow-up action by the user.
This action will close the pop-up window and perform an attempt to continue using the application. Note that this might mean that the project can be corrupted, and unexpected issues may arise.
In case this fails and the pop-up window with the issue re-appears, you need to pick one of the other follow-up actions.
This action will restart the current application that encountered the issue. You need to try and save your progress in the project, if possible, before you select this option.
When restarting you can also choose the option Recover crashed project to continue working as shown in Figure 2.
Note that by starting a new project or opening a different project, the option to recover will no longer be available for the crashed project.
Restarting the application will ensure that PLAXIS is ready to run again.
Figure 2. Option to recover the crashed project
This action will close the application entirely without saving any data for the project. When using this option, the data might be lost.
To start PLAXIS again you need to start it via the Windows Start menu, via a shortcut or a project file.
Any issues encountered with PLAXIS applications can be handled by directly reporting them to the support team: How to receive Technical Support.
In case you encounter an issue, you can reach out to the Support services by providing the relevant files – the bugreport.txt and a screenshot of the application – along with detailed information on which steps lead to this issue.
The preferred follow-up action would be to continue using the application, however, PLAXIS may still be in a state where the issue can arise again.
Therefore, it is recommended to always restart the application.
Make sure to try and save your progress in the project, if possible, before you select this option.
