| | Product(s): | MicroStation | |
| | Version(s): | CONNECT | |
| | Environment: | N\A | |
| | Area: | Project Navigation | |
| | Subarea: | DGN Links | |
How to attach several links from file to elements in MicroStation
- Open the explorer tool
- Move to the link Tab
- Create or add new link sets.
I created a link set named Office table for example, then press ok
- Afterward I create the link from file (PDF)
Search for the document to link, in this case the document format is PDF
- Once the link from file is added underneath Office Table I can do right click with mouse on top of the new pdf displayed on explorer and select the option add link to element.
- A message appears asking you to select the element.
- You can add new links from file afterwards using the icon link from file, for example to attach images.
See Video
How To Delete Multiple Links
Other Language sources
Español
Italiano
| | Original Author: | Maria Munoz | |
