| Version(s): | CONNECT, 2023 | ||
| Area: | Properties | ||
| Subarea: | Item Types |
The following video which can be found in the 'Files' tab will introduce you to creating a Report in MicroStation CONNECT Edition and later versions of MicroStation.
This video will introduce you to, creating a Report from an existing Item Type (PC > Identification) and covers following features:
MicroStation CONNECT Edition - Item Types - Reports
| Original Author: | Leonard Jones |
