| Version: | V8, XM, V8i, CONNECT, 2023 | ||
| Area: | Print/Plot | ||
| Subarea: | N\A |
How do I get MicroStation plot files (pdfs) to be created in the same directory where the design file is located?
Select File Print> Edit Printer Driver Configuration (pdf.pltcfg) - Choose Base Properties tab>Default Print File Name>File Name: "$(noext(_DGNFILE))"
When printing to PDF the output File extension is not defaulting to PDF
| Original Author: | Marion Powell |
