| Application | PLAXIS 2D |
| Version | PLAXIS 2D CONNECT Edition V22 Update 1 |
| Date created | 25 May 2022 |
| Date modified | 25 May 2022 |
| Original author | Micha van der Sloot - Bentley Technical Support Group |
With the release of PLAXIS 2D 2023.1, it is now possible to directly read cross sections from Seequent Central. For more information, please see Import Leapfrog geological cross sections from Seequent Central into PLAXIS 2D
When dealing with imported geometry, the workflow to import stratification geometry from CAD files has become much easier with the improved functionality in PLAXIS 2D CONNECT Edition V22 Update 1.
In this video, we will show you how to set up a cross-section inside Seequent's Leapfrog Geo to directly import this in PLAXIS 2D CONNECT Edition.
Bentley and Seequent: Together we are stronger.
