| Version(s): | CONNECT | ||
| Area: | Tables | ||
| Subarea: | N\A |
Also check when selecting the Table using the Element Selection tool that 'Disable Handles' is not active in the Tool Settings dialog
| Original Author: | Carl Myhill |
