Once the user adds a sensor that can measure movement, such as prisms, IPIs and SAAs, it is possible to configure the Slope Stability Mode with vectors and different color codes to show the movement's direction and intensity.
The user can configure metrics, units and calculation parameters as it is possible to be done in a graph profile.
It is also possible to add as many thresholds as necessary and adjust their limits and color codes.
Once configured, the vectors will look like in the figure below.
