This article describes the Reality Data widget of the Digital Twin module.
The Reality Data Widget offers a consistent Reality Data consumption experience across all of Bentley’s Powered by iTwin web applications.
There are multiple distinct workflows for optimizing and uploading Reality Data to the ProjectWise ContextShare. Those workflows are grouped into two distinct categories:
The following Reality Data formats are optimized for use in Powered by iTwin web applications and listed in the Reality Data Widget:
Icon |
Type |
Extension |
Cesium 3D Point Cloud |
.json |
Cesium 3D Tiles |
.json |
OpenStreetMap Buildings |
Third-party resource |
Web Ready 3D Scalable Mesh |
.json |
Web Ready Point Cloud |
.opc |
Web Ready Terrain Scalable Mesh |
.json |
No matter which workflow is used to publish Reality Data to ProjectWise ContextShare, the Reality Data Widget is your gateway to list, manage visibility and control display settings of Reality Data that are associated to the current iTwin, and optimized for use in Powered by iTwin web applications.
When a pencil icon is displayed next to Reality Data's name, it means that it is being authored by another user and may be incomplete.
Use the eye icons to turn on/off the display of Reality Data in the application's viewport.
Click the name of Reality Data in the list to open its properties.
Click on the ellipsis (…) next to the reality data to open its display settings. You can modify settings like transparency and override color to change the display of the reality data.
The Reality Data Widget is your gateway to list, manage visibility, and control display settings of all the Reality Data that are associated with the current iTwin, and optimized for use in Powered by iTwin web applications. On this page, you will learn about the available options to filter the Reality Data list.
Use the Search icon to filter the list of Reality Data using text criteria.
Use the “Filter” icon to filter the list of Reality Data using advanced property-based filters.
