| Version: | CONNECT, 2023 | ||
| Area: | Solids | ||
| Subarea: | Parametric Solids |
When using the Cut Solid with Curve tool to cut solids, I cannot control which portion of the resulting cut element is kept.
After selecting the cutting profile with the Cut Solid with Curve tool, press the Shift key to invert the side of the cut. Then issue a data point to complete the cut.
Regular Cut: select solid to cut > select profile to cut with > data point
Inverted Cut (using Shift key): select solid to cut > select profile to cut with > press Shift key > data point
To Create a Cut Using an Element Profile - online help doc
| Original Author: | Jayson Perry |
