| Version: | V8i, CONNECT | ||
| Area: | Configuration | ||
| Subarea: | User Preferences |
You may want to backup your preferences or distribute standard preferences to other machines.
1. set MS_USERPREFSEED
2. delete any local upf files on the machine
The combination of this cfg variable and other variables can allow for floating preferences from machine to machine
How to Back Up and Restore User Preferences
How to reset user preferences and delete MicroStation's temporary files
Troubleshooting user preferences issues
| Original Author: | David Trejo-Rodriguez |
