| Application | PLAXIS 2D |
| Version | PLAXIS 2D 2023.1 |
| Date created | 10 March 2023 |
| Date modified | 10 March 2023 |
Unlock the potential of digital twins with PLAXIS 2D 2023.1. Utilize Leapfrog to easily create 3D geological models from digital site investigation data and create arbitrary 2D cross-sections across the model. The geological model and the cross sections can be published to Central, Seequent's cloud-based visualisation and collaboration platform, serving as a single source of truth. Once the Leapfrog data is published in Central, use the import geometry from Central option in PLAXIS 2D to easily generate the geometry.
