| Version(s): | 23.00.xx.xx | ||
| Area: | Open/Save | ||
| Subarea: | Not Opening |
There are times when attempting to open a file in MicroStation can be delayed either due to the file, it's location or the application being used to open the file.
File is located on network. When attempting to open the file MicroStation does not recognize a file protocol on the server, it only reads the file from the location.
A file or any reference or raster attachment might delay the opening of the file.
Try copy the file locally to see if this improves the performance.
File is local. Workspace and Workset might be located on network drive.
Try opening the file with "No Workspace" and "No Workset"
File is located local with no custom workspace or workset. Go to Task Menu bar, right-click and open Task Manager. Check to see if the MicroStation is in a "Not Responding" state.
Long delay with spinning wheel opening read-only file.
Set the following variables in your configuration - this will especially help when experiencing the issue with network files.
MS_DGNFILE_OPEN_FOR_WRITE_RETRY_LIMIT
(DGN Open for Write)
If set, shortens delay in opening a DGN that is already open for editing elsewhere.
See Also:
Opening "In Use" File Takes Too Long - MicroStation Wiki - MicroStation - Bentley Communities
Performance issues encountered while opening specific DGN files.
Check Message Center for reported issues of large level name dictionaries being encountered.
See Also:
