MicroStation crashes on start up (restore defaults)
 Product:MicroStation
 Version:CONNECT
 Environment:N\A
 Area:Exception
 Subarea:N\A
Ideally collect the following, log a Service Case and work with the Support team in troubleshooting the issue.
•   Crash logs - check video
•   Event logs - check video
The following workaround of “Restore Defaults” has fixed the crashes for some Users.
Note: Your current User Preference settings, will be lost when you perform a “Restore Defaults”
Also, if you have custom configuration that you have added to your environment through the Manage Configuration tool,
click here: New in MicroStation CONNECT Edition Update 17 – Manage Configuration - MicroStation Blog - MicroStation - Bentley Communities,  these will first, need to be backed up.
To do this find these two files in this location C:\Users\[User Name]\AppData\Local\Bentley\MicroStation\10.0.0\prefs\
cache.ucf
configuration.xml
Copy these files out to separate location on your machine. These files store the workspace information stored in workspace environment.
Now use restore default settings by adding “ –restoredefaults” to MicroStation shortcut and start it.
•   Look for MicroStation shortcut on your desktop. If you don’t find it, create one
•   Right click on properties
•   In the Target after microstation.exe add this string " –restoredefaults"
    e.g. "C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\microstation.exe" –restoredefaults
•   Double click on MicroStation shortcut to perform the restore
•   Remove " –restoredefaults" once the default settings are restored.
If the RestoreDefaults is successful the following dialog should appear
Restore MicroStation to Factory defaults
Other language sources
Español ;  Français ; Italian ; Deutsch
 Original Author:Leonard Jones
