Manual Data Import Options
Back to Product Wiki
There are a couple of options available to users to house manually imported data collected by manual readings or sensors not connected to the iTwin IoT cloud. This section of articles will review those options.
In iTwin IoT there are multiple options to put in manual measurements for a sensor.
The two main methods are:
1. File Import - Manual Import (multiple or single sensor)
2. Explorer - Manual Observation input (single sensor)
For information on manually importing data via the File Import please read through this help article.
First step is to navigate to the Explorer and find your sensor that you want to input data for.
Click "Add Observation" in the upper right corner for your sensor configuration page.
Here you can manually add values and define the timestamp for the observation.
