Assets
An asset profile allows you to visualize your project from a }System Health perspective. The Assets module brings an efficient way to review the system overall.
This article will cover:
Hexagons
All sensors will be clustered in hexagons. The further zoomed out the more the sensors will nest into one larger icon and when zoomed in, the icons will break apart to show the sensors separately.
Sensor Data
Hovering over the hexagons will bring up the Assets tool-tip. It will provide small graphs to show and determine data activity without opening a specific graph.
Sensor Location
The location of these sensors can only be set on the sensors' configuration page.
