| Version(s): | 08.11.09.829 | ||
| Environment: | Windows 10 | ||
| Area: | Printing | ||
| Subarea: | Design Script |
Invalid Printer Driver Configuration File <filename>.pltcfg . See Message Center for more information.
In Message Center appears: Cannot open printer driver configuration file <filename>.pltcfg
Unable to access Windows printer '\\<server name>\<printer (share) name>
The same printer driver works fine on other computers running the very same MicroStation version.
Using the default printer drivers, no errors are seen
Edit the Windows printer driver configuration file under TAB Paper Sizes and fill in Paper Size Name AND the corresponding Windows Form Name.
