This section contains the PLAXIS 2D Tutorials
PLAXIS 2D Tutorial showcasing the model of a circular footing for load - settlement curves
PLAXIS 2D Tutorial showcasing how to investigate drained and undrained slope stability and obtaining the Factor of Safety.
This PLAXIS 2D Tutorial shows how to set up a deep excavation
Learn how to stabilize a rock mass with discontinuities after a slope road cut using PLAXIS cables.
PLAXIS 2D Tutorial showing to obtain surface settlements due to tunnel construction and check structural integrity
This PLAXIS 2D Tutorial uses the Hoek Brown model to study rock behaviour and an NATM tunnel underneath a slope
A PLAXIS 2D Tutorial how to model a deep excavation and dewater a excavation pit
This PLAXIS 2D tutorial explores the use of design approaches (e.g. Eurocode 7, Design approach 3D) for a deep excavation project
The consolidation process and the influence on the stability is studied in this PLAXIS 2D tutorial for a road embankment
This PLAXIS 2D Tutorial walks you through the steps to use wells for deep excavation dewatering in a groundwater flow analysis
This PLAXIS 2D Tutorial explores the use of a cyclic accumulation model for offshore applications: UDCAM-S
Setting up a transient groundwater flow analysis through an embankment is explained in this PLAXIS 2D Tutorial
In this PLAXIS 2D Tutorial, a dam with a reservoir is modeled, simulating different drawdown scenarios to check the stability
This PLAXIS 2D Tutorial models the dynamics soil response from a generator in a 2D axisymmetric model and explores damping behaviour
This PLAXIS 2D tutorial example shows the effect on the surrounding soil of a single blow during pile driving
In this tutorial we will apply an earthquake signal and inspect a building's response.
In this PLAXIS 2D Tutorial, a lock is set dry and exposed to temperature changes. The temperature effects on the soil are explored in this lesson.
This PLAXIS 2D tutorial shows how freeze pipes can help stability for tunnel construction.
See also
