| Version(s): | 10.15.00.74 | ||
| Area: | Installation | ||
| Subarea: | Troubleshoot New Installations (Single Users) |
It is important to note the requirements may change with version updates, so check the latest Installation requirements prior to install.
In addition, also check the version being installed is compatible with other required applications such as ProjectWise.
Consult with your IT or CAD/SITE Administrator if you have one prior to installing MicroStation CONNECT Edition, as they may have a Preconfigured install.
Here are some resources to help you find MicroStation CONNECT Edition Requirements
Help
Blogs
CONNECT Wikis
MicroStation Connect Edition System Requirements
Installation of MicroStation on Mac computer
Pre CONNECT
Installation of Desktop Pre requisites for MicroStation V8i on Windows 10 Operating System
Operating Systems supported by MicroStation versions
Requirements For MicroStation V8 XM Edition [TN]
User attempting to install prerequisite 08.11.07.03
Return to
