| Application |
PLAXIS 2D, PLAXIS 3D |
| Version |
PLAXIS 2D CONNECT Edition V22 PLAXIS 3D CONNECT Edition V22 PLAXIS 2D 2023.1 and later PLAXIS 3D 2023.1 and later |
| Date created |
May 25, 2022 |
| Date modified |
Oct 29, 2026 |
This page gives an overview of Material property changes between PLAXIS CONNECT Edition V21.01, PLAXIS 2023.2, PLAXIS 2024.3, PLAXIS 2025.1. and PLAXIS 2026.1
For all the changes between versions check the full overview in the PDF attached in Downloads section.
The Material object data structure has been updated to be more flexible for future developments.
Also, the naming convention has been made more consistent: any property name now follows CamelCase formatting, except where the first "word" and its casing represents a geotechnical meaning. Examples:
- Soil model will be written as .SoilModel
- initial void ratio einit will be written as .eInit
- Mohr-Coulomb's stiffness Eref will be written as .ERef
- Hardening Soil's oedometer stiffness Eoedref will be written as .EOedRef
- Hardening Soil's stress dependency power m will be written as .PowerM
This page will highlight in green the changes to the most used parameters. For a full list of current .Property names, please check the Objects reference (available via the PLAXIS Help menu) or use the echo command targeting the material object.
Latest changes
With the release of PLAXIS 2026.1 no changes are considered on any of the items.
Last update: Oct 29, 2026
Quick list
Soil - General
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .MaterialName |
.Identification |
.Identification |
.Identification |
.Identification |
| .ninit |
.nInit |
.nInit |
.nInit |
.nInit |
| .einit |
.eInit |
.eInit |
.eInit |
.eInit |
Soil - Mechanical
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .Kwn |
.Kwn |
.Kwn |
.KwnRatio |
.KwnRatio |
Update for consistency |
Soil - Groundwater
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .perm_primary_horizontal_axis |
.PermHorizontalPrimary |
| .perm_vertical_axis |
.PermVertical |
.PermVertical |
.PermVertical |
.PermVertical |
Soil - Interface
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .InterfaceStrength |
.InterfaceStrengthDetermination |
This was an implicit setting. It was made explicit in V22.00. |
| .Rinter |
.Rinter |
.Rinter |
.Rinter |
.Rinter |
It is required to first set .InterfaceStrengthDetermination to "Manual" or "Manual with residual strength" |
| .ConsiderGapClosure |
.GapClosure |
.GapClosure |
.GapClosure |
.GapClosure |
| .InterfaceStiffness |
.InterfaceStiffnessDetermination |
Naming of options has been changed in V22.00 |
| .InterfaceKn |
.knInter |
.knInter |
.knInter |
.knInter |
When Interface stiffness is set to Direct |
| .InterfaceKs |
.ksInter |
.ksInter |
.ksInter |
.ksInter |
| .EoedRef |
.EoedInter |
.EoedInter |
.EoedInter |
.EoedInter |
Used for UDSM and Modified Cam-Clay |
| .cref |
.CInter |
.CInter |
.CInter |
.CInter |
| .phi |
.PhiInter |
.PhiInter |
.PhiInter |
.PhiInter |
| .psi |
.PsiInter |
.PsiInter |
.PsiInter |
.PsiInter |
Soil - Initial stresses
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
.K0Determination |
.K0Determination |
.K0Determination |
.K0Determination |
| .K0Primary |
.K0Primary |
.K0Primary |
.K0Primary |
.K0Primary |
It is required to first set .K0Determination to "Manual" |
| .K0Secondary |
.K0Secondary |
.K0Secondary |
.K0Secondary |
.K0Secondary |
| .K0PrimaryIsK0Secondary |
Soil - Mohr-Coulomb
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .ERef |
.Eref |
.Eref |
.Eref |
.Eref |
| .Gref |
.GRef |
.GRef |
.GRef |
.GRef |
| .Eoed |
.EOed |
.EOed |
.EOed |
.EOed |
| .cref |
.cRef |
.cRef |
.cRef |
.cRef |
| .Einc |
.EInc |
.EInc |
.EInc |
.EInc |
| .verticalref |
.VerticalRef |
.VerticalRef |
.VerticalRef |
.VerticalRef |
Following the CamelCase formatting |
.EInc |
.EInc |
.EInc |
.EInc |
New since V22.00: in favor of Ginc |
| .Ginc |
x |
x |
x |
x |
Direct input of Einc in stead of Ginc |
| .cinc |
.cInc |
.cInc |
.cInc |
.cInc |
Soil - Hardening Soil/HS Small
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .Gref |
x |
x |
x |
x |
Deprecated. Instead use .EURRef |
| .E50ref |
.E50Ref |
.E50Ref |
.E50Ref |
.E50Ref |
| .EoedRef |
.EOedRef |
.EOedRef |
.EOedRef |
.EOedRef |
| .EurRef |
.EURRef |
.EURRef |
.EURRef |
.EURRef |
| .powerm |
.PowerM |
.PowerM |
.PowerM |
.PowerM |
| .Pref |
.pRef |
.pRef |
.pRef |
.pRef |
| .Rf |
.RF |
.RF |
.RF |
.RF |
| .nu |
.nuUR |
.nuUR |
.nuUR |
.nuUR |
| .K0nc |
.K0NC |
.K0NC |
.K0NC |
.K0NC |
| .cref |
.cRef |
.cRef |
.cRef |
.cRef |
| .verticalref |
.VerticalRef |
.VerticalRef |
.VerticalRef |
.VerticalRef |
| .cinc |
.cInc |
.cInc |
.cInc |
.cInc |
| .G0ref |
.G0Ref |
.G0Ref |
.G0Ref |
.G0Ref |
* only for HS small |
| .Cc |
.CC |
.CC |
.CC |
.CC |
Alternative parameters for stiffness |
| .Cs |
.CS |
.CS |
.CS |
.CS |
Soil - Soft Soil/Soft Soil Creep
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .MuModified |
.muModified |
.muModified |
.muModified |
.muModified |
| .Cc |
.CC |
.CC |
.CC |
.CC |
| .Cs |
.CS |
.CS |
.CS |
.CS |
| .Ca |
.CAlpha |
.CAlpha |
.CAlpha |
.CAlpha |
| .nu |
.nuUR |
.nuUR |
.nuUR |
.nuUR |
| .cref |
.cRef |
.cRef |
.cRef |
.cRef |
| .K0nc |
.K0NC |
.K0NC |
.K0NC |
.K0NC |
Soil - NGI-ADP
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .UnloadingShearStiffness |
.GURsUARatio |
.GURsUARatio |
.GURsUARatio |
.GURsUARatio |
| .nu |
.nuU |
.nuU |
.nuU |
.nuU |
| .ReferenceShearStrength |
.sUARef |
.sUARef |
.sUARef |
.sUARef |
| .IncreaseOfShearStrengthWithVerticalRef |
.sUAInc |
.sUAInc |
.sUAInc |
.sUAInc |
| .RelativeTriaxialCompressiveShearStrength |
.sUCTxsUARatio |
.sUCTxsUARatio |
.sUCTxsUARatio |
.sUCTxsUARatio |
| .RelativePassiveStrength |
.sUPsUARatio |
.sUPsUARatio |
.sUPsUARatio |
.sUPsUARatio |
| .RelativeDirectShearStrength |
.sUDSSsUARatio |
.sUDSSsUARatio |
.sUDSSsUARatio |
.sUDSSsUARatio |
| .AxialFailureStrainTriaxialCompression |
.gammaFC |
.gammaFC |
.gammaFC |
.gammaFC |
| .AxialFailureStrainTriaxialExtension |
.gammaFE |
.gammaFE |
.gammaFE |
.gammaFE |
| .ShearFailureStrainDirectSimpleShear |
.gammaFDSS |
.gammaFDSS |
.gammaFDSS |
.gammaFDSS |
| .InitialMobilization |
.tau0sUARatio |
.tau0sUARatio |
.tau0sUARatio |
.tau0sUARatio |
| .verticalinc |
.VerticalInclination |
Rock - Hoek-Brown
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .Eref |
.Erm |
.Erm |
.Erm |
.Erm |
| .Gref |
.GRef |
.GRef |
.GRef |
.GRef |
New in V22.00: alternative input to Young's modulus |
| .UnconfinedCompressiveStrength |
.AbsSigmaCI |
.AbsSigmaCI |
.AbsSigmaCI |
.AbsSigmaCI |
| .HoekBrownParameter |
.mi |
.mi |
.mi |
.mi |
| .GeologicalStrengthIndex |
.GSI |
.GSI |
.GSI |
.GSI |
| .DisturbanceFactor |
.Disturbance |
.Disturbance |
.Disturbance |
.Disturbance |
| .mb |
.mb |
.mb |
.mb |
.mb |
Hoek-Brown mb |
| .s |
.s |
.s |
.s |
.s |
Hoek-Brown s |
| .a |
.alpha |
.alpha |
.alpha |
.alpha |
Hoek-Brown a |
| .sigt |
.SigmaT |
.SigmaT |
.SigmaT |
.SigmaT |
Rock mass parameter |
| .sigc |
.SigmaC |
.SigmaC |
.SigmaC |
.SigmaC |
| .MaximumDilitationAngle |
.psiMax |
.psiMax |
.psiMax |
.psiMax |
| .MinorPrincipalStress |
.sigmaPsi |
.sigmaPsi |
.sigmaPsi |
.sigmaPsi |
User Defined Soil Model
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .UserDLLName |
.DllFile |
.DllFile |
.DllFile |
.DllFile |
New in V22.00: property is enumeration. Use string representation when setting the value |
| .UserModel |
.ModelInDll |
.ModelInDll |
.ModelInDll |
.ModelInDll |
Plates (2D)
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .MaterialName |
.Identification |
.Identification |
.Identification |
.Identification |
| .Elasticity |
.MaterialType |
.MaterialType |
.MaterialType |
.MaterialType |
Material Type needs to be set explicitly |
| .IsIsotropic |
.Isotropic |
.Isotropic |
.Isotropic |
.Isotropic |
| .EA |
.EA1 |
.EA1 |
.EA1 |
.EA1 |
| .nu |
.StructNu |
.StructNu |
.StructNu |
.StructNu |
| .d |
.d |
.d |
.d |
.d |
Thinkness of the plate |
| .Np |
.Np1 |
.Np1 |
.Np1 |
.Np1 |
| .Mp |
.MP |
.MP |
.MP |
.MP |
| .Gref |
x |
x |
x |
x |
Deprecated. Instead use .EA1 |
| .ElastoplasticMKTable |
.MkappaDiagram |
.MkappaDiagram |
.MkappaDiagram |
.MkappaDiagram |
* only used when .MaterialType is set to Elastoplastic (M-kappa) |
Plates (3D)
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .MaterialName |
.Identification |
.Identification |
.Identification |
.Identification |
| .Elasticity |
.MaterialType |
.MaterialType |
.MaterialType |
.MaterialType |
| .w |
.Gamma |
.Gamma |
.Gamma |
.Gamma |
| .IsIsotropic |
.Isotropic |
.Isotropic |
.Isotropic |
.Isotropic |
| .d |
.d |
.d |
.d |
.d |
| .Nu12 |
.StructNu12 |
.StructNu12 |
.StructNu12 |
.StructNu12 |
| .sigy11 |
.YieldStress11 |
.YieldStress11 |
.YieldStress11 |
.YieldStress11 |
* only used when .MaterialType is set to Elastoplastic |
| .sigy22 |
.YieldStress22 |
.YieldStress22 |
.YieldStress22 |
.YieldStress22 |
| .W11 |
.W11 |
.W11 |
.W11 |
.W11 |
| .W22 |
.W22 |
.W22 |
.W22 |
.W22 |
Geogrids
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .MaterialName |
.Identification |
.Identification |
.Identification |
.Identification |
| .Elasticity |
.MaterialType |
.MaterialType |
.MaterialType |
.MaterialType |
| .IsIsotropic |
.Isotropic |
.Isotropic |
.Isotropic |
.Isotropic |
| .N1Eps1Table |
.N1eps1 |
.N1eps1 |
.N1eps1 |
.N1eps1 |
* only used when .MaterialType is set to Elastoplastic (N-eps) |
| .N2Eps2Table |
.N2eps2 |
.N2eps2 |
.N2eps2 |
.N2eps2 |
* only used when .MaterialType is set to Elastoplastic (N-eps) and anisotropic |
Beams (3D)
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .MaterialName |
.Identification |
.Identification |
.Identification |
.Identification |
| .Elasticity |
.MaterialType |
.MaterialType |
.MaterialType |
.MaterialType |
| .w |
.Gamma |
.Gamma |
.Gamma |
.Gamma |
| .BeamType |
.CrossSectionType |
.CrossSectionType |
.CrossSectionType |
.CrossSectionType |
| .PredefinedBeamType |
.PredefinedCrossSectionType |
| .Iyy |
.I3 |
.I3 |
.I3 |
.I3 |
| .Izz |
.I2 |
.I2 |
.I2 |
.I2 |
| .sigy |
.YieldStress |
.YieldStress |
.YieldStress |
.YieldStress |
Embedded beams
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| embeddedbeamrow() |
embeddedbeam() |
embeddedbeam() |
embeddedbeam() |
embeddedbeam() |
Removed the word row from the command. PLAXIS 2D only |
| .MaterialName |
.Identification |
.Identification |
.Identification |
.Identification |
| .Elasticity |
.MaterialType |
.MaterialType |
.MaterialType |
.MaterialType |
| .Lspacing |
.LSpacing |
.LSpacing |
.LSpacing |
.LSpacing |
PLAXIS 2D only |
| .BeamType |
.CrossSectionType |
.CrossSectionType |
.CrossSectionType |
.CrossSectionType |
| .w |
.Gamma |
.Gamma |
.Gamma |
.Gamma |
| .Iyy |
.I |
.I |
.I |
.I |
PLAXIS 2D only |
| .Iyy |
.I3 |
.I3 |
.I3 |
.I3 |
PLAXIS 3D only |
| .Izz |
.I2 |
.I2 |
.I2 |
.I2 |
PLAXIS 3D only |
| .SkinResistance |
.AxialSkinResistance |
| .Tstart |
.TSkinStartMax |
.TSkinStartMax |
.TSkinStartMax |
.TSkinStartMax |
| .Tend |
.TSkinEndMax |
.TSkinEndMax |
.TSkinEndMax |
.TSkinEndMax |
| .SkinResistanceTable |
.MultiLinearAxialSkinResistance |
* only used when .AxialSkinResistance is set to Mulit-linear |
| .Tmax |
.TMax |
.TMax |
.TMax |
.TMax |
* only used when .AxialSkinResistance is set to Layer dependent |
| .TLateralStart |
.TLatStartMax |
.TLatStartMax |
.TLatStartMax |
.TLatStartMax |
| .TLateralEnd |
.TLatEndMax |
.TLatEndMax |
.TLatEndMax |
.TLatEndMax |
| .Fmax |
.FMax |
.FMax |
.FMax |
.FMax |
| .DefaultStiffnessFactors |
.DefaultValues |
.DefaultValues |
.DefaultValues |
.DefaultValues |
PLAXIS 2D only |
| .AxialSkinStiffnessFactor |
.AxialStiffnessFactor |
PLAXIS 2D only |
| .LateralSkinStiffnessFactor |
.LateralStiffnessFactor |
PLAXIS 2D only |
| .PileBaseStiffnessFactor |
.BaseStiffnessFactor |
PLAXIS 2D only |
Cables
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
.Nptens |
.NpTens |
.NpTens |
.NpTens |
.Npcomp |
.NpComp |
.NpComp |
.NpComp |
cable() |
cable() |
cable() |
cable() |
Removed the word bolt from the command. PLAXIS 2D only |
cablemat() |
cablemat() |
cablemat() |
cablemat() |
Anchors
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
| .MaterialName |
.Identification |
.Identification |
.Identification |
.Identification |
| .Elasticity |
.MaterialType |
.MaterialType |
.MaterialType |
.MaterialType |
| .Lspacing |
.LSpacing |
.LSpacing |
.LSpacing |
.LSpacing |
* only for PLAXIS 2D |
| .FMaxTens |
.FMaxTens |
.FMaxTens |
.FMaxTens |
.FMaxTens |
| .FMaxComp |
.FMaxComp |
.FMaxComp |
.FMaxComp |
.FMaxComp |
| .FResidualTens |
.FResTens |
.FResTens |
.FResTens |
.FResTens |
* only used when .MaterialType is set to Elastoplastic with residual strength |
| .FResidualComp |
.FResComp |
.FResComp |
.FResComp |
.FResComp |
| .FMaxTensPerLength |
x |
x |
x |
x |
Removed in favor of .FMaxTens. PLAXIS 2D only |
| .FMaxCompPerLength |
x |
x |
x |
x |
Discontinuity
| V21.01 |
2023.2 |
2024.3 |
2025.1 |
2026.1 |
Comment |
.General.DiscontinuityMaterialSet |
.General.MaterialSet |
Updated for consistency purposes |
.Groundwater.DiscontinuityGroundwater |
.Groundwater.FlowParameters |
