How to run a Limit Equilibrium Method analysis from PLAXIS 2D
Finite Element Analysis - Limit Equilibrium in One Click
Application PLAXIS 2D
GeoStudio 2D (SLOPE/W)
Version PLAXIS 2D 2023.2 and later
GeoStudio 2023.1 and later
Status Technology Preview
Date created 10 May 2021
Date modified 25 September 2026
Easy one-click conversion between PLAXIS 2D and GeoStudio (SLOPE/W)
Figure 1. Easy conversion from PLAXIS 2D to GeoStudio SLOPE/W
Introduction
For the determination of a Factor of Safety, the strength reduction method is a very powerful tool to obtain the most critical slip surface, a slip surface that may be circular but can also have any other form. However, there may be circumstances in which more information is required than just the most critical slip surface or when the critical slip surface is of minor importance from an engineering point of view. For instance:
In these cases, determining a Factor of Safety using the Limit Equilibrium Method would be the solution. With Limit Equilibrium, it is possible to specify exactly what part of the model the Factor of Safety must be determined while the method would still have the benefit of determining the most critical, possible non-circular, slip surface in that area. It would also allow within one model to determine different factors of safety for different parts of the model.
With PLAXIS 2D, you are able to quickly open the same model with the same geometry, the same staged construction configuration, the same loading conditions and the same material assignments in GeoStudio SLOPE/W to run your Limit Equilibrium Method analysis.
1 Import from and Export to GeoStudio
Since the release of PLAXIS 2D 2023.2, you can access the following options under the File menu to:
2a. Conversion PLAXIS to GeoStudio
Follow these instructions for conversion from PLAXIS 2D to a GeoStudio SLOPE/W (Limit Equilibrium) file:
  1. Ensure the PLAXIS 2D project is saved.
  2. Navigate to the menu option, File > Export GeoStudio 2D
  3. PLAXIS 2D will prompt for the configuration of the remote scripting server:
    • configure to an available port, and secure password (defaults are OK) and click to Start server.
    • click on Close.
  4. The tool will present a dialogue for a selection of what to convert.
  5. Select the conversion settings, e.g. which slip direction you want to consider, which phase to consider, etc.
  6. Click to Convert.
  7. The conversion process will start, resulting in a message with:
    • Conversion warnings and info.
    • Options to view the full log file.
    • And open the newly generated LEM model file.
  8. Using the button, you can select to directly open the newly generated GeoStudio model file.
  9. After a few seconds, GeoStudio will be loaded with the model.
Figure 2. PLAXIS 2D to GeoStudio converter tool user interface directly after launching
2b. Conversion GeoStudio SLOPE/W to PLAXIS 2D
Follow these instructions for conversion from a 2D GeoStudio geometry to a PLAXIS 2D model:
  1. Ensure the GeoStudio file is saved.
  2. Open PLAXIS 2D Input and start a New project.
  3. Navigate to the menu option, File > Import GeoStudio 2D
  4. Select a source GeoStudio file (*.gsz)
  5. Select the appropriate geometry.
    • The tool will warn when a model is still open in PLAXIS 2D to prevent data loss.
  7. The conversion will start a new PLAXIS model and builds up the model according to the data in the GeoStudio model.
Note: Only geometry and soil material assignments are converted from GeoStudio to PLAXIS.
Figure 3. Import GeoStudio 2D to PLAXIS 2D user interface
Limitations
Limitations converting PLAXIS 2D to a GeoStudio model
The phase configuration of a PLAXIS 2D model can be converted into a GeoStudio (Limit Equilibrium) model. By default, the geometry, material assignments and available parameters, distributed loads and the water table will be converted.
GeoStudio's SLOPE/W model starts by default with a Morgenstern-Price method and a Circular Entry and Exit method.
In the current version, the following limitations/restrictions apply:
Note that the PLAXIS 2D to GeoStudio model converter will indicate this in the conversion log. Make sure to read it before continuing in GeoStudio.
Limitations specific to reading GeoStudio files to convert to PLAXIS 2D
Requirements
The "Import/Export to GeoStudio 2D" tool requires:
Older PLAXIS Versions - Previous instructions
Below are instruction documents for PLAXIS Version 2021 and 2022.
See also
