| Version(s): | 10.15.00.74 | ||
| Area: | Installation | ||
| Subarea: | Troubleshoot New Installations (Single Users) |
Having obtained the MicroStation CONNECT Installation software executable (*.exe) required version, for most users simply running the *.exe will be fine and the user can follow the prompts to Install the application.
For other users they may run into problems here are some areas for review.
Check your connected to the Internet (If problems in this area consider creating a Deployment Image on a machine that does have Internet access)
Temporarily Disable any Anti-Virus protection prior to Install (Remembering to reenable following successful install)
Ensure you have Permission to install
Should you encounter problems during install and the above has not helped, please contact your Site Administrator in the first instance. If requiring further assistance collate the Installation logs and raise a Service Request with Bentley (See link below)
Here are some resources to help you with installing MicroStation CONNECT Edition from downloaded executable.
Help
Blogs
CONNECT Wikis
How to install MicroStation as Administrator
MicroStation CONNECT Edition Update 4 Installation Options
Pre CONNECT
Return to
