| Version(s): | 10.15.00.74 | ||
| Area: | Installation | ||
| Subarea: | Troubleshoot New Installations (Single Users) |
When required MicroStation CONNECT Edition Language Packs can be Downloaded from https://connect.bentley.com/ see also these Software Download Instructions and Installed.
Here are some resources to help you with downloading and installing Language Packs
Help
Blogs
CONNECT Wikis
How to Install Language Pack for MicroStation CONNECT Edition
How-to-download-and-install-microstation-connect-10-00-00-25-new-portal
Software Administration Service
Pre CONNECT
Microstation (SELECT Series 3) Update 1 (08.11.09.357) - Issue with localised versions TN
Return to
