| Version(s): | 10.15.00.74 | ||
| Area: | Installation | ||
| Subarea: | Troubleshoot New Installations (Single Users) |
Having obtained the MicroStation CONNECT software executable (*.exe) and run the install there is an option to select your Organizations standard Configuration, however this can be overlooked.
Please contact your Site Administrator for the location of your Organizations Configuration should one exist.
To correct this, you could remove or modify the installation via the Windows ‘Add Remove Programs option’ or alternatively by modifying the installed ConfigurationSetup.cfg install
Here are some resources to help you with redirecting MicroStation CONNECT Edition to an Organizations standard Configuration
Help
Blogs
CONNECT Edition - Deploying or Updating ConfigurationSetup.cfg
Configuration Installation Options and Microstation Connect Edition Update-4
Configuration blog series- Folder-structure-changes
CONNECT Wikis
Pre CONNECT
MicroStation error "no Disk in drive"
Return to
Requesting Further Assistance
