| Version(s): | 10.15.00.74 | ||
| Area: | Installation | ||
| Subarea: | Troubleshoot New Installations (Single Users) |
Having installed and Configured MicroStation CONNECT Installation, you will need to ensure that your entitled to run the software.
Entitlement is obtained through the Subscription Entitlement Service
To check your Entitlement ensure your logged into the CONNECTION CLIENT and run the Bentley Licensing Tool ( Delivered with the CONNECTION Client )
Select the Entitlements tab and check the ‘Access’ column status.
If the ‘Access’ is not ‘Allowed’ then you should contact your Site Administrator in the first instance for assistance, but if unavailable or unable to help then please collate Logs and contact Bentley (See Link Below)
Here are some resources to help you with Entitlements
Help
Blogs
CONNECT Wikis
Understanding the Subscription Entitlement Service (SES) Workflow
Pre CONNECT
Understanding the (Legacy) SELECTserver Workflow
Product Activation TechNotes and FAQs
Return to
