How to create a Bentley account and submit a Support Case
Application All supported Bentley applications
Version All supported Bentley versions
Date created 29 July 2020
Date modified 28 February 2025
General
When using any Bentley software, our support teams are ready to assist you with problems encountered.
To reach the support teams, a support Case needs to be submitted and processed. Then, one of our support team members can help you in detail.
Creating an account and submitting a support Case
Below, the required steps are explained, allowing for submitting a support Case:
  1. You will need to create a Bentley account.
    This is explained on the Registered User - Individual User Process article.
  2. Once successfully created, you should be able to access your page on the CONNECT Center: https://connect.bentley.com/
  3. An Account Administrator in your organization should add you to one of the managed groups, giving access to the Bentley applications and entitlements (e.g. software downloads, software usage).
    To find your Account Administrator, you can select "How are you CONNECTED" on the Welcome Banner in the CONNECT Center. For instructions, see the article on CONNECT Center Overview:
  4. When everything is set accordingly, you should have access to downloads, software usage and services, including being able to submit a support Case by following the information on the How to receive Technical Support article.
Useful links:
