| Version(s): | 10.15.00.74 | ||
| Area: | Installation | ||
| Subarea: | Troubleshoot New Installations (Single Users) |
This article is to provide information regarding working with MicroStation in Virtual Environments and for those users Working from Home.
Please contact your Site Administrator or IT department in the first instance, if they are unable to assist then please check the resources below before contacting Bentley.
Help
Blogs
CONNECT Wikis
Pre CONNECT Wikis
Return to
