Solved issues - Overview - PLAXIS
This section contains a list of resolved: issues in PLAXIS 2D and PLAXIS 3D. See subpages for all resolved: known issues.
History
PLAXIS 2D/3D 2024.3
Released: May 2025
The following issue was resolved:
Solved Known issue Application Issue #
Severe divergence error when running a dynamic analysis with custom connections in PLAXIS 3D PLAXIS 3D 1394428
PLAXIS 2D/3D 2024.2
Released: July 2024
Error when using unsupported Elastoplastic (M-κ) embedded beam elements in PLAXIS 3D PLAXIS 3D 1347993
PLAXIS 2D/3D 2023.2.1
Released: October 2023
The following issues were resolved:
Error when generating the mesh for embedded beams set to grout body PLAXIS 3D 1268947
Groups created in green modes are lost when reloading PLAXIS 2D
PLAXIS 3D
1268947
Incorrect visualisation of phreatic level in PLAXIS 3D 2023.2 PLAXIS 3D 1268947
Dynamic point loads in axisymmetric 2D models do not consider the radius PLAXIS 2D 1092643
OpenSSL vulnerability not affecting PLAXIS 2D or PLAXIS 3D PLAXIS 2D 1149242
PLAXIS 2D/3D 2023.1
Released: February 2023
Report generator issue with Material information when different material types for plates and anchors used in projects PLAXIS 2D 1025141
PLAXIS 2D/3D CONNECT Edition V22.02
Released: October 2022
Some Input tables and Output results may not consider project units in PLAXIS CONNECT Edition V22 [V22.01] PLAXIS 2D
PLAXIS 3D
861673, 989888
PLAXIS 2D/3D CONNECT Edition V22.01
Released: May 2022
Released: January 2022
PLAXIS 2D/3D CONNECT Edition V21 - Service Release 1
Released: February 2021
PLAXIS 2D/3D CONNECT Edition V20 Update 4
Released: September 2020
PLAXIS 2D/3D CONNECT Edition V20 Update 3
Released: June 2020
SciTE issues when running a Python script PLAXIS 2D
PLAXIS 3D
SW-47996
Objects names with special Unicode characters may fail in meshing PLAXIS 3D SW-47115
PLAXIS 2D/3D CONNECT Edition V20 Update 2
Released: March 2020
Permeability value change not stored when changing from From data set to None PLAXIS 2D
PLAXIS 3D
SW-21183
Ignoring suction after a fully coupled flow-deformation analysis in Safety analysis gives incorrect stresses in PLAXIS 2D PLAXIS 2D SW-45205
Detailed data per specific release for older versions not yet available
